Arlo Q
I really like the Arlo Q better than the Nest cam. However, I am hesitant to buy because my router is an Apple Airport Extreme model A152. Should I go ahead and hope that reconfiguring my SSID will make it work? Thanks for any comments.
do you have guest access on that router?
No, but I can set one up.
The guest WiFi can be set up with generic settings, right? The simpler, the better. Within security reason, of course.
Arlo Q
