Arlo Q won't sync
  • 1614 Views
cit222
Just quit working -  deleted old cameras - upgraded Mac - still not working
Need all details. What have you tried and what do you see? The computer has nothing to do with this - it's about your WiFi, the camera and the setup process.
Arlousernumber1
My ArloQ won't sync. I unplugged it to move it elsewhere and it wouldn't sync up again. I removed the device in the app in order to reinstall using the app and QR code screen. I disabled the 5Ghz band on my router to do it but that didn't work either.
Does anyone have any ideas? Please
Arlousernumber1
I got mine working by going to devices and removing then reinstalling on the app then turning off my mobile data on my phone and factory reset the Arlo Q using a paperclip.
Then on the app followed the instructions to install a new camera.
I hope this helps.
