Arlo Q with solid amber light
  • 2 Replies
  • 1140 Views
CameraFunTimes
I have an Arlo Q that's worked fine for years. Recently it shows as disconnected and has a solid amber light.
Does anyone have any ideas what might have happened? Failed firmware update?
Is there anything I can do to try get this camera working again? I've power cycled and attempted a factory reset but no luck.
There haven't been any updates for a few years now for the Q.
Try a different power supply to see if that makes a difference. Otherwise, I'd wager it's dead.
CameraFunTimes
Thanks - didn't think to try another power supply. Worth trying but unfortunately didn't help. I guess I'll switch it out for an Essential Indoor or similar.
