When Arlo Q was new it sinked up fine - message to update firmware everything still good - 1 week later it went off line - tried resinking - resetting - no luck - returned it for new one worked fine as the first one did - unpluged it for a day to mount it to its new location in the house and now doesnt sink - sometime software shows camera but says not on line - reset it and it just keep on looking for connection - I have 4 wireless and they work fine - I bought 6 Q's and only have two that still work from original sink - did I get 4 bad cameras?
I am only 10 feet from the router - I have rebooted router - reset camera - tried both moble device and computer - new camera out of the box worked - maybe its the updated firmware?
The fast thing to do is swap at the store. Otherwise, open a case with support.
Well that is sort of what I did - Bought 2 pack and 1 went off line with no luck getting it back on - bought 2 more, the one I unplugged for a day to work on a new mount and it never came back on line - I'm afraid that after the inital setup and firmware update that if they go off line I will not be able to sink them again - inital sink worked fine on all of them, the one that drop off line and the one I unplugged for a day will not sink again - the one did show up on my account but showed as offline, but captured a couple motions - never showed on line and will not view live
