Arlo Q will not Sync to base
  • 1 Reply
  • 2220 Views
Anitacarson
I have had the system for about a year.  The outside battery cameras are working fine.  But my two inside cameras (plug in electrical wall outlet type) went off line and I am having trouble syncing them.  I held the button on the base station 2 seconds til it starts flashing and the held the sync button on the Arlo Q down for 2 seconds.  It flashes slow blue and after a few minutes times out to orange.  Any suggestions?
The Arlo Q cameras DO NOT sync to the base..they connect to your home wifi system directly.
Reset the Q cameras by holding in the reset button for 10 secs till the front led flashes....
Bring the Q back by sybcing it to your home wifi by going to the LIVE VIEW screen and use the ADD DEVICE button ( bottom of page ) using Q cam as your choice
