Arlo Q white noise
How come when i view it live i hear a lot of white noise, like radio white noise of an empty channel?
You shouldn't.... how is it if some talks in a normal voice a few feet away ??
maybe lower the volume on the unit...
End answer is contact Netgear Support, maybe they are aware of the issue
I have the same issue. Bought two cameras and one of them hade severe white noise and I got it replaced. I bought an additional camera so now I have three. All produces a little white noise, but nothing that actually disturbes. The other issues with the cameras are much more concerning than some minor noise...
I have a new Arlo Q and experience the same white noise described. I contacted Netgear support and was told that is normal, but still question that reply. I can say that voices could still be picked up clearly both far and near to the speaker when remotely connecting, without having to adjust the Arlo volume. I keep it at maximum volume. I have lowered the volume on my IPAD to reduce the noise, but still need to test if voices can be heard. also, have noticed sometimes getting an audio alert as a result of a single loud click sound..and I am confident it is not a sound coming from within the home. Note also I am now having problems connecting to my Arlo remotely, either connnecting slowly or not at all, and notice the white noise stops during a poor connection.
Arlo Q
