Arlo Q temperature range
  • 13 Replies
  • 10341 Views
  • 7 In Conversation
DH29
What is the termperature range for the Arlo Q? I'd like to use it on a front porch (protected from rain). Thanks.
13 REPLIES 13
Hula_Rock
Prodigy Prodigy
Prodigy
Indoor only.
Yup.  You're on your own if you want to use it outdoors.  It may be fine - or not.  Personally, I'd think the issues would revolve around moisture, even if protected.  The USB wall wart and the unsealed camera lend themselves to allowing moisture in.
hokeysmoke
Virtuoso
Virtuoso
I would like to know the temperature range as well.  Mine has a green screen in the app saying, "Your camera needs to cool down before you can use it."  What's more annoying is that it's been this way for a couple of hours, and I cannot restart it remotely.  It just fails with a "Your camera is busy and cannot restart" error.
hokeysmoke
Virtuoso
Virtuoso
Update: The camera auto-restarted after 3.5 hours showing the "cool down" message.  I guess this is good since it recovered.  I still would like to know what the appropriate temperature range is for this product.  It's nowhere on the spec sheet.
Guess mine is vented well enough even contained in a cardboard box to try to reduce reflections (using it to monitor through a window).  What ambient temperatures is yours experiencing?  Is it in some sort of surround?  Is it near other heat-generating equipment?
hokeysmoke
Virtuoso
Virtuoso
It's in a window with a shade partly down behind it to reduce reflections (like the box you have).  There is a lot of space around it as I have 2x6 walls and the shade is at the very back.  See below for the location with the shade raised.  It was about 80F outside when it happened and the sun does heat up the bricks on this side of the house, but it seems odd to me that an IP cam, drawing less than 10 watts, would be so affected by this kind of heat.
If your Q keeps getting HOT and dropping out due to same , I'd contact Netgear and see what they say... your the first to my knowledge with this issue
hokeysmoke
Virtuoso
Virtuoso
I discovered today that the sun does hit the camera directly.  I moved it to a spot where that doesn't happen and will see if it recurs.
Mine gets hit with late afternoon sun through an old window with storm window (so no low-E glass, etc.).  Maybe it's low enough to not cause issues or the glass has magical properties...
hokeysmoke,
Have you seen the same error messaging after having moved your Arlo Q to a different location, out of direct sunlight?
Please let us know!
hokeysmoke
Virtuoso
Virtuoso
JamesC wrote:
hokeysmoke,
Please let us know!
So, far I have not had any additional errors.  However, it has been 20 degrees cooler outside since the error, so it will take a bit more time to determine if there is still a thermal issue with my setup.
hokeysmoke
Virtuoso
Virtuoso
JamesC wrote:
hokeysmoke,
Please let us know!
As I mentioned in the other thread, the message appeared again on another warm day for 6 hours.  I recorded the ambient temperature next to the camera and it was 43.5 degrees C (110 F) when it shutdown.  It did not recover until the temperature dropped to 31 degrees C (88 F).
jafuhrer
Have one Q Camera inside a detached garage, in Wisconsin for the past year.  There is no heat, cooling or insulation in the garage.
No issues with performance other than it is near the limit of WIFI range and the camera has drop out every so often.  Not big issue because very rare and not out for long time.
Pleased with the performance in temps from -10 to 95 outside temps
Hope this helps,
