  • 7 Replies
  • 1270 Views
Sandymike
I am a new owner, and I like the setup.
I have 2 pro 2 cameras, and would like a bit more distance for motion detection.
I have read that the model Q has a lot longer range, like 50 ft compared to 15 ft for the pro 2.
I have seen a few posts from 2 years ago and looking for updates.
Any new ideas for weather proofing a "Q"
How are they holding up outside, how do you weather proof.
Mike
7 REPLIES 7
michaelkenward
Sensei Sensei
Sensei
The Q Plus, same design as the Q, is not suitable for outdoor use.
Just another user
The Q model is not made for outdoors....  That being said;
yes, the Q has better range over 50 ft as the trigger is by pixel change over a PIR device ( when the picture changes it will trigger )
Also I have use the Q outdoors ( in summer ) in a covered area which could not get water on ... no issues over the two months used.
As to sealing up, there was someone on the site that did same.... not pretty but it worked.
thread here;
https://community.arlo.com/t5/Arlo-Q/How-to-weatherproof-an-Arlo-Q/m-p/1222526
Sandymike
Yep I know the current design is not meant for outside use.
If used outside it may void the warranty.
However there are always those that see the benefits of the technology, and want to use it "off label"
Just trying to see how they do it.
Sandymike
Thanks TomMac,
I did see that post, doesn't look like there has been any activity on that thread.
There is at least one other post that I have seen.
Mike
michaelkenward
Sensei Sensei
Sensei
If you are after wifi range, and have a bottomless budget, the new Floodlight doesn't need a hub. A wifi source will do. But it also requires a subscription for cloud recordings.
Just another user
Sandymike
Thanks Michael,
My wifi is not the issue, and I know I could just add additional arlo pro cameras.
I like the different way the Q detects motion.
Here is an older thread that talks about weather proofing a Q
https://community.arlo.com/t5/Arlo-Q/Arlo-Q-or-Q-Plus-for-Outdoor-Use/m-p/1133211
Mike
Sandymike
I understand that it is not suitable for outdoor use.
However I know others have done this.
I am looking for any recent ideas on how to make the Q series more weather resistant.
Mike
