Arlo Q Outside in hot temperature
would like to know if arlo q can be put outside in the hot az temps like under a eve and has any one had problems with it
First of al the Q is not out door rated for weather....
That said I had it under an covered area in warm weather without issue ( maybe 90F ).
There is a high temp range if I can find it...there were tow cases, 1) inside a storm door and insulate door in summe heat 2) on a radiator
In those cases the screen read " cam must cool down "
specs say; 122F
Arlo Q
