Arlo|Smart Home Security|Wireless HD Security Cameras|NETGEAR
Re: add Arlo Q on android app
Did you try a browser as suggested above?
Message 51 of 56
Highlighted
Hi, I try with my desktop computer browser and it look like I can insert the SSID manually  but it's a desktop computer with no ability to scan the barcode .... Ill try today with a laptop to see if it's also working...
Thank's
Message 52 of 56
Message 53 of 56
WHy can't you scan the QR code using a computer? It displays the QR code and you use the camera to scan it. What barcode are you referring to?
Message 54 of 56
Yes, but the problem is that the camera is mounted on the wall in a different floor from the desktop computer.
I'll try today to dismount the arlo from the wall and try to do it with the desktop computer...
This is disappointing that the company didn't made a fix for the application, I paid good money for the camera's...
Thanks Smiley Happy
Message 55 of 56
Re: Arlo Q On Android App I Can Not Select A WIFI SSID
Hi, try this: on your Android device WiFi settings - remove / delete / forget your connection. Reconnect and it will hopefully work.
Message 56 of 56
