Today I had an issue with my Arlo Q camera. I couldn’t seem to be able to control it via the app or see live feed.
I decided to reinstall it:
1. I deleted the camera from the app
2. I reset the camera
3. I reinstalled the camera via the app.
The installation went fine but the camera did not show in the app.
The camera is working as it is producing notifications and is recording clips.
I have repeated steps 2 & 3 a couple of times.
The camera shows in the notification settings and I have moved it out of notifications but it continues to send them.
Has there been a software update in the last 24 hours.
ArloQ Camera
IOS 14.5.1 (latest)
Latest version of Arlo app
Cameras and recordings both disappeared whilst in the app reviewing some items in the library.
IOS 14.5.1
ArloQ cameras
App version 3.2 (2202)
Morning,
Here we go again. All my 3 Arlo Q's have suddenly disappeared from my list. The list is empty and i can only "add" devices.
Meanwhile they are active, give notifications of movement and/or sound, the counter of movie clips recorded increases, but no actual clips are added. The library stays empty.
I am not able to switch them off or delete them. Curious if i can add them again while the are "active in the background"
Anyone else having the same issues? Getting tired of all those random incidents...
Kind regards
edit:
Just after posting my message, i saw netvuk's post. Apparently we are having the same issue.
Hi,
Apparently we have the same issue, although i am not able to remove devices from my app. The devices list is empty.
If you delete the device and then restart the app it will have gone
Yes it sounds like the same issue - was ok until this morning
I'm having the same this morning.
Logging in via web shows the cameras listed under System > Device Orders but don't appear under 'My Devices'
I have them linked into Smartthings and they are there!
Have not managed to solve it yet.
Must be on Arlo’s side since it seems to be a general issue for all.
Same issue here
Reset Camera
Added new device, setup went correctly thought to there finish
Then No Device in the list
But on MyArlo - videos appear in Library and I am getting plenty of motion sensor messages
I am having the exact same issue. All my cameras have disappeared from the app this morning.
I have deleted and reinstalled the app and reset and re-registered the cameras and they are still not showing. I am still getting motion detection alerts and the footage via the web interface, but not on the app.
Is it possible that there is a server issue at Arlo? Seems strange this is happening to so many people on the same day.
48 hrs to sort this out before I migrate to Blink or Ring or anyone else!
Hi I have the same issue. My Arlo Q disappeared from the list. And I can't added it back.
Thanks for your "tech point of view"! I hope support at Arlo takes a look at this and fixes the problem...
Lets hope Arlo repairs or rolls back asap...
BTW: There is a link to check Arlo status:
Same here, all three Arlo Qs suddenly not showing, but outdoor SmartHub Arlo is showing. And tried rebooting device & switching to another device, but made no difference. First time that’s happened, must be a server issue.
My cameras disappeared from my app last night. They still trigger motion alarms, but I cannot manage them anymore.
This is the case for both my iPhone app and login to the Arlo site from a workstation PC, so I know it's not the phone.
I've tried the following.
- Reset the cameras, resync to account
- Logout/Login from app
- Delete App, reinstall
Thoughts?
Also, I determined they still show up in System > Device Order. I just cannot manage them at all.
I had the same issue, a router reset cleared it up.
Appears to be fixed.
Now fixed
Arlo Q
