Arlo Q Delay (1080p vs 720p)
I noticed there's more of a delay when using 1080p instead of 720p. Does anyone else have the same issue?
I have 100/100 speeds but I've noticed this happens because Arlo is only connecting to 2.4g instead of 5g. Does anyone else have this issue?
Well. I have noticed a few seconds delay from live to actual viewing...
With your speeds tho, the rez shouldn't make that much diff unless there's a botteneck somewhere...the higher rez max peaks at 1.5mbs and the 720 is about 800kb.
Any way you can move the 5ghz closer... as you prob know the 2.4 travels better and the cam prob sees it as a stronger signal.
Arlo Q
