Arlo-Q Back screws type and size
  • 1 Reply
  • 1231 Views
Blackbird74
Hello,
Does anybody happen to know the type and size of the 5 back screws of an Arlo Q?
Is that a micro Torx or something?
Thanks,
Bb
They do kinda look like Torx but it's not clear enough to say. I bought a security bit set at Harbor Freight that has damn near every type and size bit you're likely to run into. For $10 it's worthwhile to try:
https://www.harborfreight.com/security-bit-set-with-case-100-pc-68457.html
