  • 5109 Views
  • 2 Likes
Handsome_Guy
I want to put an Arlo Q in my unheated garage.  However, I only see documentation that indicates it must be used "indoors".   Does anyone know exactly what range of temperatures are acceptable for an Arlo Q?  I've seen a range for the outdoor unit but not for the indoor Arlo Q.
Thanks for any help.
Haven't seen one either as to temp specs,  but the camera is self warming... ( warm to touch when running ) I would guess no problems as long as it's dry..
JellyBean012345
 Did you ever receive an answer?  We're looking at putting one in the garage, too.
Indoors generally refers to sealing from weather, not temperature.  I can't be sure that there aren't limits on the low temperature but the warmth of the camera internals should help prevent that from being an issue unless the temps are pretty extreme. Upper temps are limited by the camera with a notification that the camera is too warm and will resume working when the temp drops sufficiently.
