  • 4 Replies
  • 2149 Views
Itbehook
When I first bought my Arlo Q two years ago or so, it showed recordings a few seconds before the motion was detected. Now, I see that it only starts recording the very second motion is detected, it doesn’t go back two to three seconds. Did Arlo change the coding or did I change a setting on my end? Any input would be appreciated. Thanks!
Streak2
Master Master
I would try and restart the wireless router to which the Arlo Q is connected.
If you are using the Arlo app then try using the web interface to see if the problem also shows up there
https://arlo.netgear.com
Streak2
Master Master
My Q still has this feature. Nothing has changed. Try and restart the camera using the app and see if it corrects itself.
Itbehook
I tried that twice and it still isn’t working. Any other ideas?
Streak2
Master Master
Itbehook
I reset the router and it works now! Thank you.
