Arlo Model # VMS3330 multiple location with a single base
  • 2 Replies
  • 4029 Views
Peduardo73
I just purchased the Arlo Model # VMS3330 for my dad .. we were able to install all 3 cameras and connect the base.
Dad has his home site and business site which are about blocks in distance from each other.  Can I move one of the three cameras to the home since it will be on a different Wi-Fi connection?
Nope. The camera only has a wifi connection to the base. Your home or work wifi has no bearing. You'd need a separate base at the new location to sync the camera to.
As mentioned, you just can't move the camera... but if you can get a second base yu can use it and one of the or another camera in the second location on the same account...
There is no limit on the number of bases, Only number of cameras on your service level ( basic = 5 max  )
