Any way I can reconnect my Arlo Q to the router remotely?
  • 4 Replies
  • 6442 Views
Hasechen
I installed an Arlo Q in my place in the Philippines two weeks ago and then came back here to the U.S. where I'm based. Everything was working fine until yesterday where it started showing the message "Your device is not connected. Make sure it's connected to your router and has a working Internet connection". I don't think the problem is the internet service I have there since my brother that goes there to check can still use it for other purposes. It's frustrating because I can't physically be there to fix it at this point. Is there any way I can solve the problem online? Thanks.
If you can't use the interface to access Settings be, My Devices, your camera, Restart button at the bottom, only physical access will work. Unplug the camera and plug back in. That should clear it.
An alternative is to use something like the WeMo remote switches which would allow you to remotely power cycle the camera.
BTW, I've had issues changing settings in my router which can cause the Q to not reconnect automatically.
Hasechen
Thanks for your suggestion!
HurdyGurdy
totally never thought about that - i to have random powerdowns when away and had to text the pet sitter to go and fix things. Have a bunch of tplinks around so will quickly connect to it !
