ARLO Q - Record time does not change
  • 2 Replies
  • 1872 Views
RonNH
I know HOW to change the record time. Problem is when I try to change it, then save it, the camera still only records 60 seconds.
I have “Record for a fixed length of time” checked. I set the slider to record 120 seconds. But all I get is 60 seconds or less. I would expect an actual fixed length.
I have tried unchecking it, checking the “Record until activity stops”, save, but it still records for 60 seconds whether motion continues or not.
When I go back to verify my change did save, it does show correctly the modification I made.
I even restarted the camera - still the problem.
You state a restart of the camera, but did you do a full reset ?
RonNH
Thank you for your response.
Considering the cameras are 1200 miles away - reset isn’t available. They are being used to monitor home care for my 94 year old father and the home health aides won’t or can’t handle a full reset like that.
