  • 2 Replies
  • 1491 Views
mmarlo
Recently my Arlo Q+ (Wired, PoE, CVR) has begun having issues when I'm live viewing either from the web or the iOS or Android apps (Heavy pixelation or loss of image, intermittently no audio on the stream, occasional complete drop-outs).  The network topology hasn't changed, nor have there been any recent upgrades or additions to the hardware on the network.  It's wired, so it's probably not a mirowave somewhere mucking with me.  The device does have an SD card installed, but it's largely unused since I switched to CVR since I understand that they're not sophisticated enough to cache data and retransmit if the network is congested or the like.  Any clues on potential causes, diagnostics, or fixes?
Try turning off CVR to see if that helps with recordings and live view. I'm testing using the 50Hz flicker setting based on anothr user's comments which seems to help some.
mmarlo
Turning off CVR rather defeats the purpose of having the camera in the first place.
I've had no issues with this camera previously (it's been in place for nearly a year)
I'll run some tests but it's not a long term solution.
  • 2 Replies
  • 1492 Views
