POE adapter distance from Arlo Q plus
  • 2 Replies
  • 4346 Views
home_alone
Hi,
The POE adaptor will not fit the intended spot for the camera, but the pictures of the back of the camera are not detailed. Can I pull a Cat5 to the Arlo Q Plus with the POE adaptor on the other end of the wire, ie: close to the POE switch?
Thx
Don't think so.... I think the Poe adapter plugs in via a USB 3 type plug into the camera
home_alone
Thanks!
  • 2 Replies
  • 4347 Views
