Mounting Options
  • 1 Reply
  • 3579 Views
dimdem
We're getting pretty frustrated with trying to position an Arlo Plus camera to watch over the cars in our driveway, and we're starting to think that a better option might be an Arlo Q Plus inside mounted to look at them out a window. But from pictures the mounting for the Q seems pretty inflexible, with the camera at a fix distance and angle from the plate. Am I right about this, and if so then are there some creative workarounds? Does it have a place where you can screw a mount into the back?
dimdem,
Arlo Q/Q Plus are connect to the mount with a ball pivot. The mount can be in a fixed position and the camera can freely pivot for the desired angle.
Take a look here for more information: How do I mount my Arlo Q or Arlo Q Plus cameras?
  • 1 Reply
  • 3579 Views
