Arlo SD solely
  • 1 Reply
  • 3001 Views
cilice
Hi all,
I just bougth an Arlo Q plus camera for a research protocol in order to evaluate the activity in a "wild" environment (internet is not available).
I thought that I could record and save continuously the video on the SD card, but I only have a record when an event occur...
Is it possible to activate CVR on SD?
Thank you for your answer.
Not to my knowledge....
The mem card is a backup if the interent goes down... it will record motion detected movement at the same time it is sent to the cloud.
The CVR option relies totally on the cloud recording ( and that does not go to the mem card )
  • 1 Reply
  • 3002 Views
