  • 5 Replies
  • 3878 Views
NightWatcher1
I have an Arlo Q Plus. I have the Q Plus tucked inside a box. I see all 4 walls of the box plus the room I am looking at. During Live View, I can Zoom In so I only see the room. This is what I want to see. But when I go to My Library, all recorded videos show the room and the 4 walls of the box. How can I zoom In so the recorded videos only show the room and not the 4 walls of the box? I assume I need to Zoom In and then SAVE this zoom setting, but how? Right now I  am using a PC Laptop with IE but I have purchased an IPad which I will be using to view my account also.
5 REPLIES 5
You go to SETTINGS>VIDEO...
click on snapshot
after it takes a new pic, click on ZOOM.... use mouse to change box size
Now click on ZOOM again ( if you notice, it says SAVE now by mag glass )
After saving the size will stay as selected.
To get to full size, reverse the procedure
NightWatcher1
I take snap shot, click on zoom, but nothing happens-no box appears or I cannot zoom in.. The zoom icon does change to save but how do I zoom in and out. I am using my laptop with no mouse.
Did you click on the Create New Zone button?
NightWatcher1
I did click on the new zone button.  I saw the box outlined in green. The box will move left or right but I cannot stretch it into any shape. The box only moves left or right and remains the same shape.
You need to grab the corners.  Can be a chore with a mobile device - perhaps using a computer would be a better choice.
  • 5 Replies
  • 3879 Views
