Arlo Q Plus, SD Card, CVR
  • 5 Replies
  • 7661 Views
juga
If I purchase an Arlo Q plus as well as a CVR plan, is there a way to set it to record continously 24/7 to both the SD card and the cloud?
No... NTMK
The CVR fuction will record 24/7 AND the trigger events ( motion, sound ) are indicated on the time line BUT only the trigger events go to the library and the sd card
5 REPLIES 5
No... NTMK
And you wouldn't want to.  I did a manual record from live view one time for a bit over an hour and the resulting file was over a GB.
juga
A gig per hour is not bad at all. if there was an option to record 24/7 to SD card, I would pay a monthly fee for both.
juga
Will it at least do 24/7 recording to the SD card when the internet is down?
Only if you have motion detected 24/7.  🙂  The card gets whatever is normally sent to the cloud.
  • 5 Replies
  • 7662 Views
