Hi Arlo Community!
I only realized recently (albeit late) that the Arlo Q plus has been discontinued, but does local storage with the Arlo Q Plus still work if you don't have a subscription?
I only see 7 days' worth of recordings for my account. I understand that's cloud storage for legacy support for users without a new subscription plan. But what happened to the ability to use my local storage on my Arlo Q plus? I doubt my MicroSD card failed. Does anyone have any experience with this?
Thanks,
A.S.
@aa021812 wrote:I only realized recently (albeit late) that the Arlo Q plus has been discontinued, but does local storage with the Arlo Q Plus still work if you don't have a subscription?
You can still use the microSD card without a subscription. You need to remove the card and connect it to a PC to view the recordings (which has always been the case with the Q plus). They never showed up in the app or PC browser.
Thank you!
