Arlo Q Plus - Does the POE adapter handle power and wired internet connection?
  • 3113 Views
d33kae
Hi,
Does the POE adapter handle both power and wired internet connection? I dont have WIFI covereage in the spot I want to put it.
Thank you!
Yes it does... POE stands for power over ethernet.  But keep in mind that your router/switch must support POE ( supply power )
Also, you can use the Ethernet connection without PoE but you'll have to use the USB power supply to do so.
Terk
You could also use a POE injector if your switch doesn't support POE, I have use this with the Arlo Q Plus
  • 3114 Views
