Adding a camera to Arlo Q Plus
  • 3949 Views
Grif11
I just purchased the Arlo Q Plus that I will connect via ethernet cable downstairs. I have spotty internet- and doing straight to the source seemed like the best option. If this works, fingers crossed, - I was hoping to add on.   I wanted to get a second camera for upstairs, which will need to be connected via WIFI/Bluetooth. What is the most economical way to do this? Its essentially to keep an eye on my dog- since he hangs out in my office while im out.  Im not sure if which Arlo is comaptable with the Q series. any help appreciated! Thank you!
The Arlo And Arlo Pro will work as separate systems with the Q ...that is they can not be arme all at the same time but the Arlo gets armed and the Q cams get armed as individual units
Arlo is a "motion detect then record" type of system...dependin on how much you want to view or record makes a big diff if the system would work well for you.
Grif11
Thank you. I just need to monitor - camera 2 recording not as important. Thinking another arlo Q is the best option to arm simultaneously?
Grif11,
Arlo Q/Q Plus are standalone cameras. You can add a second Arlo Q to your existing account (allowing both to be view from the same account) but each will have to be armed and disarmed separately.
  • 3950 Views
