router
  • 4083 Views
koshburr
I only have internet connection with a verizon jetpack/hotspot wifi. will the subject router work with my netgear wnce3001 adapter by plugging the acapter into the router internet in port? I am trying to hook up multiple surveillance cameras.
steve_t
Master Master
Yes, that should work so long as the connection is fast enough
koshburr
 Thanks for responding. After reading my original question I noticed that it might not of been clear the way I worded the question or meant to word it. The subject router I am referring to using is a net gear n300 model. There is no means to physically plug into the Verizon hotspot, it is strictly wifi. To be more specific the wnce3001 wifi adapter would pick up signal from hotspot and plug into the line in port on the n300. Then I could cable from n300 to a surveillance system that is not wifi capable. I could then hopefully cable and/or wifi from n300 to other devices also. If this would work will there be a static/dynamic ip issue?
steve_t
Master Master
That should work just fine (as long as your internet connection is fast enough)
