  • 7 Replies
  • 931 Views
beneb2
i have done everything--unplugged replugged--reset--nothing works HELP!
beneb2
well before these -arlos I had hard line eqp.--no work just a pleasure--I liked the arlos because I could move them around--but oh my god they are a lot of work always going offline and batteries going dead--in this case, above i switched back to the vmb 3000 and reset all my 5 cameras all seems to be good so it looks like the vmg 4000 had a heart attack--nuff!!- said, I'm so close to dumping these -thanks for all those that looked at this -be well and safe regards
bene
7 REPLIES 7
What status are you seeing on the base station LEDs?
beneb2
the LEDs are solid green
Thanks.  Have you used both the app and PC (browsing to my.arlo.com)
beneb2
no app---just desk top
Does using incognito/private browsing mode make any difference?
beneb2
no no difference--i took everything down and let it chill for a while ---when I started it up everything was clean and working--until i turned it off and went back in the black cover screen came back --i can see movement behind it--when i click on the number of activities it opens and is normal but when I go out of it the cover screen comes back--
beneb2
bene
