my wifi has changed how do i change it on arlo
Arlo base station is connected via ethernet cable. It shouldn't need any alterations. Just plug and play
You don't have to change anything with Arlo...Arlo plugs into the new Ethernet port on your router...
your account log in doesn't change...sign in as normal.
