Motion detection only seems to work near the center of the area that Arlo is focused on. Is there a way to sense near the edges verses the center?
It may be as "simple" as the camera positioning and how motion moves in the field of view. What's the sensitivity setting? Post a screenshot for suggestions.
I just upped my sensitivty to 95 on 2 of my 4 camera's to see if this helps my situation (not OP).
In an OpenSource solution I used to use (went Arlo for true wireless functionality) I could define a polygon for motion detection.
I have no issue with motion being detected in center frame, my problem is i see so little b/c there is no pre-roll buffering. I catch the mailman 'closing' my mailbox. Not walking into the center of the frame or even opening the mailbox, but closing it and walking away. This is at 80 sensitivity and mailbox being near-center of frame.
I want devices to keep a 3/5 second buffer and when motion detected, it writes that buffer. What happened to get to the activation point? Often, that is the key to everything. Accident or thief.
PittCaleb
Again, screenshots would be useful.
