iOS 2.5.1 Update is here
Finally here.. Check App Store.. It's prolly' best to Delete the old and start fresh with the new Update.. If not, Go to Profile and logout first and login again.. Just to make sure no Glitch.. Hope it fixes most of the bugs! Goodluck!
It looks the same to me with Delays/LiveStream timeout/"Alarm" banner... It just changed from 2.5.0 to 2.5.1.. Did you do anything to this update Arlo? Ok maybe some such as Library names but the major important ones are still not fixed.. Sad.. Can you take a look at your Server fix to take care of these Delays/Timeout 3-4cams simultaneous livestream?
Sadly this is not a fix at all.. Still the same for me getting the a major delay on Livestream/record then it timeout in less than 2min, far from the intended 29min I used to get before this new update... Also, I set my recordings in 1min 35sec and all I get on my 5-cams are 13-35sec intermittently each, again so far off from my settings. .. Also, "Alarm Banner" still there when LiveView on landscape mode..
