how do i reset my arlo pro
  • 1 Reply
  • 5354 Views
peggyelpers
steve_t
Master Master
The camera? Put open the battery compartment and wait a few seconds and the close the battery compartment. The camera will be reset and should sync itself to the base
Restarting the base, you can power cycle it or you can restart it from within the app or web interface under the settings menu
