  • 6 Replies
  • 7139 Views
freycinet
hi,
wondering how i go about recording on a hard drive? Do I just plug a usb into the port or is there set up requiored? When it is full does it auto write over the old recordings?
freycinet
thanks Tom, very helpful
6 REPLIES 6
You will find a speed stick is easier to manage for the USB ports....
format it in fat32 ( you can do it in the program ) and there are options to overwrite or stop when it is full.... A 32gb will be plenty. ( max can be 2TB )
you can find these in the base settings
remember that this Is a backup drive and the speedstick must be ejected and put into computer to view
FAQs are your friend
freycinet
so i just go to orffcieworks and ask for a speedstick?
How do I format it as suggested? Do I plug it into the base station? Do I need to use the app?
Sorry not very tech literate!
Go to office works and ask for a speed stick or Flash drive. or thumbdrive...many names but the same
( buy a good name brand ) about 32GB or 64GB
Plug into the back of arlo base ( pro or pro2 model base ; will not work on original arlo base )
go to settings/base look for local storage
click on " > "  ( on web is easier )
see screen below, read the FAQs on usb drive
https://kb.arlo.com/1146857/How-do-I-set-up-local-storage-backups-on-a-USB-device-using-my-Arlo-Pro-...
https://kb.arlo.com/1146850/How-do-I-view-videos-saved-on-a-local-storage-USB-device
freycinet
many thanks
freycinet
great thanks tom
freycinet
