chargers!
Where in the world can I luchase a new charging cable for my ols cameras? Mine have been misplaced and the one I ordered from Amazon that was supposed to be compatible did NOT work, so back it went. This is very aggravating to say the least; love the old cameras and they atill work very well!
Many cables do work but I've run into some that have a larger plastic surround on the microUSB connector. I've whittled one or two down to fit but it's just easier to try various ones to find one that does fit. There's nothing special about the cables.
Also, be sure you're using a charger that supports Qualcomm Quick Charge. It needs to supply both 5 volt as well as 9 volt outputs. 5 volt only will not charge the battery.
