best aftermarket battery
I am using rechargeables for my cameras but I am deploying soon so I want to know whats the best aftermarket batteries out there for my cameras? Trying to avoid my wife and brother switching out the rechargeables so need something that might last 2-3 months
For the Arlo wirefree HD, I find the longest lasting CR123A batteries are Energizer ones followed by Panasonic and Duracell. These would give you the best chance of not having to change the batteries before you get back. Also, try to avoid live streaming and false triggers as much as possible while you're away, but you probably already do this now.
If you're actually talking about the Arlo Pro (because you've posted in this section), then you could consider permanent AC power or a solar panel and I'm not sure about aftermarket batteries for Arlo Pro sorry
