I use Arlo on a home computer, not a phone. On the new Feed page at my.arlo.com, I cannot delete all videos for a single day. If I have 100 clips, I must delete all 100 one by one. There is no Select All or Delete All for a day. This is a terrible downgrade from the old layout and makes the system hard to recommend. Please restore a way to delete all videos for a day in one action.
You can.
- Press the three dots in the upper right of the "Feed" page.
- Click on "Select Events"
- Select the day of the recordings you want to delete
- Click "Delete" on the bottom right.
You can.
Sorry Guru - I missed it the first time you replied, but I get it now. Again my apologies
No worries. FWIW, the feature isn't as easy to find as it might be.
Note you can also set up a filter (specifying specific event types and cameras) first. The bulk deletion only applies to the videos that are shown - not those that are filtered out.
