arlo pro starry/blurry image on one camera
- Email to a Friend
I installed the four arlo pro cameras around my house. All four work fine during daytime, and three work fine during nthe night. The fourth displays a blurry "star" shaped image during darkness so that the driveway is not decernible. It is on the corner of my garage to view down my 150ft driveway. It is located close to sensor security spot lights. The starry/blurry image is there when the lights are not on as I thought that might be the problem. They all have the Wasserstein covers.
- Email to a Friend
Post a screenshot so we can see for ourselves. A daytime and nighttime shot for comparison might be useful.
- Email to a Friend
Thanks. Don't know how to transfer the camera images from my iphone 7 to these messages - will try something.
I'll have to wait for darkness to re-create the star pattern. Meantime, I'll try and upload a daytime image.
- Email to a Friend
Use the phone's screen capture and then use the Photos icon just above the reply text box to upload. Or view a video and use the Share icon to copy the link to paste here. The latter method only works for 24 hours, though.
Dienste und Sicherung
FlexPower ONVIF Cameras
ReadyNAS for Surveillance
Switches For Surveillance
