hi,
recently, i happen to have a nest outdoor cam looking at a arlo pro cam I place outside (nest cam and arlo pro kinda facing each other).
i got some nest motion alerts at nigh. when i reviewed the nest footage, i saw that the arlo pro would randomly flashed. the flash from the arlo pro seemed to be bright enough the wall was lightened as well. i dont believe arlo pro has a flash light. was the flash light the infrared light? why would it flash from time to time? maybe motion? but the system was not armed
yes the flash would appear to the other camera if the IRs of the Arlo come on...why is an unkown.
I'd reset the camera with a battery puul/replace and check for possible arming if on schedule
