arlo pro channels
  • 1 Reply
  • 3716 Views
Danny89705
How do i Change wifi channel of your 2.4G wifi of your router? Everyday i have cameras that go offline. and one of the cameras is right next to the router.
The Arlo and Arlo PRO base run on 2.4ghz and if the base is within area of your home router, it will sellect the same channel ( on purpose )
Netgear techs have found that is the base is close and sitting on the same channel there are less collison issues with data flow.
If you must , for some reason , put you base on a diffeerent channel it must ba about 20ft or farther away from you home router.
OR as a temp fix... change you router channel, reboot the base ( may have to reset ) and the base should follow to the same channel... then change your router back to original. ( this will last only till the base unit resets or reboots )
