Wireless Arlo Pro will not record/detect motion
Hello,
I have three Arlo Pro cameras. All are online, charged, showing good WiFi connection and are armed. I have not had any recordings in 4 days. I know that there should be as I have had someone in the house and also in the other two areas being monitored. I had him walk up to each of the cameras and wave an arm. This did result in a recording and an alert notification. I can view live screens and manually record resulting in a recording in my library. Today, no recordings. I’m at a loss as to why they are not picking up the motion, recording and I am not receiving alerts. Any help is appreciated.
We are having the same problem...
i have reset our system, still nothing
at a loss at what to do now
Have you checked your active mode? Are the running men for each camera black or gray? Have you tried a base restart?
The running man is grey
i have reset the system
not sure how to check active mode?
My running man is black. Not sure about “ active mode”? Would you clarify? Thanks!
Read the FAQs here about modes and rules. Basically, use the Mode tab, select your base and see what mode is selected. Make changes as needed.
