I have my Arlo Base Unit connected to my current Sky Router via an ethernet cable and my 4 camera's connect via wifi and it all works fine.
I am about to take delivery of a new WiFi 6 Sky Router - will my Netgear Arlo Base Unit (VMB4000) (Serial No - 4RD38378A1CB4) connect to this new technology ?
It should work ok. Just connect the base ethernet to a LAN port on the new router.
WiFi 6 isn't relevant, since the base connects with ethernet. The Sky router specs I'm seeing on line all say 1 gbps ethernet, which is compatible with the base (which uses 100mbps, but gigabit ports all support 100 mbps also).
thanks very much
