Why is the arlo login website not working?
  • 9 Replies
  • 5101 Views
  • 3 Likes
  • 7 In Conversation
rfeiring
When trying to view cameras on Win10 PC at https://arlo.netgear.com/#/login, Getting message:
This site can’t provide a secure connection
arlo.netgear.com uses an unsupported protocol.
ERR_SSL_VERSION_OR_CIPHER_MISMATCH
What is needed to correct?
You just need to use the correct URL (which is my.arlo.com).
Arlo split off from Netgear 5 years ago.  Netgear kept arlo.netgear.com alive (redirecting it to my.arlo.com) as a convenience, but something must have changed on their side.
9 REPLIES 9
Dokcat
When I tried to log in to view my cameras this morning I got this message. It was working perfectly last night...
Details
(Unsupported protocol
The client and server don't support a common SSL protocol version or cipher suite.)
You should be using my.arlo.com.  That won't give you that error.
Arlo split off from Netgear back in 2018.
Hubbus
Same problem here. It just stopped this morning.
Hubbus
Thank you Stephen that works great.
brownland01
Thank you....worked for me.
rfeiring
Thank you. That solved the problem!
jdeaton
why is the web site not working. If it is eol I need a phone number to contact you.
Which web site? ARe you using my.arlo.com and not a Netgear one?
