Why 2 usb ports on the Arlo Pro base?
On the PRO base you can use the USB ports for a USB drive to backup the videos sent to the cloud ( they record to the cloud AND the drive )
It will also record if you loose internet ( and have power ) if prev set up
Yes thanks I know that but why 2 usb ports?
Bcause if you have two, and one fills up OR you pull one, it transfers over to the other
( TBOMK)
