Who's deleting video?
I'm seeing videos disappear from the library left and right, and I'm not doing it. I suspect that my mother in law is deleting them, but I can't tell for sure. Is there a way to track who's doing what?
No but change your password and revoke guest access or at least privileges. How old are the videos? If less than your plan allows, you may want to open a case with support.
Darn, I was hoping for some tracking. Oh well, I'm sure it's her, since she and I are the only ones who can delete videos. And since it's her house, and her camera, I guess she's entitled. But I wish she'd give me a chance to review them before she deletes them. She gave me this task, she should let me do it. /end rant
MILs are like that ! 🙂
Drop a USB stick in the back although I am not sure if you delete from the library if it deletes it from the stick also (I have never checked). If not then issue solved especially if you drop a tiny micro-sd card reader in there which is not even noticeable
If you are serious about your home or work security then look elsewhere! Get a ip Camera System with an NVR and some Blink XT cameras to cover the places you cannot run a cable to. You will NEVER regret moving away from Arlo!
