Which power adapter is needed for wmb4000 pro base station?
  • 1 Reply
  • 683 Views
cosmic2003
what power adapter is needed for wmb4000 pro base station
The original is spec'd at 12DC @ 1.5a , center positive, with coaxial plug of 5.5mm by 2.1mm
If you are replacing one, I suggest googling "VMB4000 replacement power adapter", you should get quite a few third party options that way.
