Hi, I have the Arlo Base Station VMB4000. What updated Arlo Cameras can I add on to this base Station? Can I add Arlo Pro 3. Arlo Pro 4 ? And will they be able to connect to my existing system?
Thank You
Yes. The Pro4 can also be connected directly to your home wifi. The newer cams do require a subscription for cloud recordings though. This link shows what cams can connect to a base/hub.
What is the difference between each Arlo SmartHub and base station?
