Which cameras are compatible with VMB4000?
  • 1 Reply
  • 6542 Views
RODRICH60
Hi, I have the Arlo Base Station VMB4000.  What updated Arlo Cameras can I add on to this base Station?  Can I add Arlo Pro 3. Arlo Pro 4 ?  And will they be able to connect to my existing system?
Thank You
dcfox1
Yes. The Pro4 can also be connected directly to your home wifi. The newer cams do require a subscription for cloud recordings though. This link shows what cams can connect to a base/hub.
What is the difference between each Arlo SmartHub and base station?
dcfox1
