Which camera has more than 20 ft motion detection distance?
  • 1 Reply
  • 850 Views
mysharona
I have the Arlo Pro and need to add a camera that has a 30+ foot motion detection. Are there any cameras that connect to my Arlo Pro base that have a longer distance for motion detection?
No.  You're wanting to go past the normal range for PIR sensors (which is what the Pro and Ultra Arlo cameras use).
You can get further if you use an Arlo Q camera, because that uses pixel processing.  However that isn't rated for outdoor use, and it needs power (no battery).  It connects over your wifi (not through the base), but could be added to your account.
