When to recharge Arlo Pro?
When is the appropriate time to recharge the Arlo Pro? When it runs down to which percentage? 5% 10% 0%??
BTW I have a spare battery, fully charged and ready to go in as a replacement. I just want to know how long the existing one can go without damaging it or the cam, if it might occur at all?
Thanks in advance!
I've done mine mostly when they've gone to zero but a few times, I knew I was likely to be away for the weekend when one would run out so got in early. Since the Arlo Pro batteries are Lithium Ion, it shouldn't really matter when you do it and you shouldn't expect damage to your battery or camera at any stage
